what is the screw on top of my tb?
RE: what is the screw on top of my tb?
well i think it controls ur car's idle, the more open it is the higher it would idle i believe. I have to go now but if you havnt gotten an answer by later today i can look it up in my service manual for ya
coo...thankx man.
ORIGINAL: OnyxCobra
well it controls ur car's idle i believe, the more open it is the higher it would idlee i believe. I have to go now but if you havnt gotten an answer by later today i can look it up in my service manual for ya
okay man this is all my service manual says about it
The idle air control valve (IAC valve)(9F715):
-is used to control engine idle speed (rpm)
-is mounted on the throttle body
-allows air to bypass the throttle plate. The amount of air allowed to bypass is determinted by the powertrain control module (PCM)(12A650) and controlled by a duty cycle signal.
The idle air control valve cannot be cleaned and must be replaced (if required).
wow guys.... you are all guessing...
oddly enough... you are all correct. this screw is the IAC adjustment screw. you can PROPERLY ADJUST the idle by turning this screw, while also grounding out the gray connector in the eec harness. This wire is also called the STI (Self Test Indicator) wire, and can be used to check for CEL codes when a OBD-1 scanner is not available.
by grounding that connector it puts the ECU into a test/adjustment loop mode. using your tac... you can adjust your idle to smooth it out, or even increase/decrease it. you SHOULD be around 800rpms... normal idle!
well...lol, id say thats a rather fine answer you have there adder! i thank ya man.
ORIGINAL: AdderMk2
jwog666
12-27-2021 08:09 PM
breaking
10-02-2015 01:27 PM
