Need Help with 5.0 automatic transmission
I have been having trouble with my transmission lately. It has been shifting at around 4k rpm instead of 2k as it usually does and now it doesnt shift at all. I need to know if anyone has any ideas of what can be wrong. Please reply and let me know
RE: Need Help with 5.0 automatic transmission
First of all is the fluid and filter in good shape?Second when did it start this?What were you doing when it started?
I had an A4LD that did this and it ended up scrapping a bronze bushing and caused me to have to rebuild the tranny.
let me guess you have first and second but not hte rest. AOD are know to
have the overdrive band go out.
1,2 and R are on the same band
3 and 4 are on the other....this band seems to go out alot. your going to need a rebuild.
E-mail www.sr7performance.com. They will know whats wrong and sells great trannys. I got a killer aod there.
Its just started about a week ago but got worse gradually...i was just driving it normally, at first i thought it was the cold weather.
We checked the fluid and it was fine but i dont know about the filter ill have to check that. Thanks for your advice.
I just changed the transmission filter and fluid today and problem wasnt solved so its decided that im gunna need to rebuild...thanks for your help and suggestions. And vfast can you tell me exactly what a shift kit does...thanks for your posts.
I overhauled my '94 AODE with the same symptoms. The problem was the one way clutch had come apart. Make sure whoever fixes it uses new parts. Sometimes good used parts can be substituted with no problem but this is not one of those cases. Ford has a new design that is MUCH better. Even if this clutch is OK, replace it with the new Ford part.
LivingInThePast
09-16-2015 12:20 PM
