how far to advance
14 is the MAXIMUM i would go without worrying about detonation.
But i wouldnt start at 14 either.Make your adjustments in small increments until you just hear some detonation and or the performancedrops off then back her up to the best last setting.
Ok thanks. i knew i should move in small incraments but i just didn't know how much it should go. What is the best ignition out there? I havn't looked to much on that yet.
[IMG]local://upfiles/5107/Qo392158490.jpg[/IMG]
14 is fine with a stock motor as long as you run 93 octane. i ran as high as 18 [motor was ice cold and outside temp was 50]before i got soem serious detonation. im running currently 15. my car is dog with anything less. but make sure your car runs cool with timing up this high or you will get detonation sooner.
K, I'll keep that in mind i will probly adjust it some were around 10-12. don't really need to run 93 octane at college there isn't much compatetion around here at all mostly cowboys and there huge desiels. thanx
[IMG]local://upfiles/5107/Jh156721478.jpg[/IMG]
