Mass Air Flow Sensor
RE: Mass Air Flow Sensor
you wont see any real improvement.
if you changed both the MassAir and the Throttle body and a cold air intake
you might pick up 10-15whp.
you would want 70mm mass air meter for 19lbs injectors and a 65mm throttle body.
you will have to port out the stock intake opening a little to match the new TB also.
Hell if you want a MAF sensor I have a 73mm C&L with the 19# injector tube (forgot color) And the blue tube for 24# injectors.
It worked great on my stock application. I had it with a MAC fenderwell cold air intake, and stock throttle body.
I ended up with a PRO-M calibrated for 24s for my new engine combo.
1996cobraconvertible
SVT Forums
13
01-07-2016 04:50 AM
TfcCDR
09-14-2015 12:08 PM
