New motor in- 1 question
Old 06-07-2006, 12:05 PM
88_5.0
88_5.0's Avatar
Default New motor in- 1 question
Well we got my "new" motor in last night and it runs like a raped ape! I've got one question- We put back on the original fan and shroud and now when you close the hood it hits the shroud and then the fan rubs on the shroud and i've already rubbed off about 1/8" off the top of the fan blades. We adjusted the shroud a little higher and the hood will just push it back down. Anyone experience this? or have any fixes?
88_5.0 is offline
Old 06-07-2006, 12:13 PM
jzgt
jzgt's Avatar
Default RE: New motor in- 1 question
Are you sure you seated the shroud in the clips in the bottom of the radiator?
This probably has nothing to do with it as it sounds like it's a shroud issue (it's hitting the hood), but did you put new motor mounts in? If so, what year were they for?
- Jeff
jzgt is offline
Old 06-07-2006, 01:02 PM
92hatchLX
92hatchLX's Avatar
i wanna hear some info. on this motor!
92hatchLX is offline
Old 06-07-2006, 01:04 PM
AdderMk2
Banned
AdderMk2's Avatar
just pull the clutch fan off and swap to an electric
AdderMk2 is offline
Old 06-07-2006, 03:48 PM
88_5.0
88_5.0's Avatar
ORIGINAL: jzgt
- Jeff
Actually we took the motor mounts out of my friends 89 SALEEN witch is having the 306 rebuilt in it.
88_5.0 is offline
Old 06-07-2006, 03:51 PM
88_5.0
88_5.0's Avatar
ORIGINAL: 92hatchLX
Well i took the motor out of an 89 GT for about $450 and the guy at the place said from what he could tell it was stock. Well first try it started right up, set the timing and everything and it has a small cam. I'm suprised it doesn't run like crap cause of speed density. The idle is fairly rough but it pulls sooo hard.
88_5.0 is offline
Old 06-07-2006, 04:12 PM
jzgt
jzgt's Avatar
Did you check the shroud to see if it's in both of the clips at the bottom of the radiator? Did you make sure the end tanks are resting in the rubber bushings at the bottom of the radiator support? Did your radiator hold downs go on easily?
- Jeff
jzgt is offline
Old 06-07-2006, 04:31 PM
92hatchLX
92hatchLX's Avatar
Sweet, what did you have in it before?
Tivo304
08-28-2023 12:19 PM
Granatelli Sales
01-20-2020 12:34 AM
Luke9222
10-22-2015 11:55 PM
04stangman
09-17-2015 01:45 PM
Quick Reply: New motor in- 1 question
