clearances
Old 07-02-2006, 09:53 PM
greenstreak9205
greenstreak9205's Avatar
Default clearances
so for those of you guys that changed your rocker arms, what did you do for valve cover clearance? the stock ones wont fit obviously, so did all of you just have to buy new ones? do they have to be the tall ones or will after market short valve covers be slightly taller (enough to clear) than the stock?
greenstreak9205 is offline
Old 07-02-2006, 10:35 PM
Scout2232
Scout2232's Avatar
Default RE: clearances
I have 1.7rr's I got the small trickflow vc's on mine and theyre good to go.
Scout2232 is offline
Old 07-02-2006, 10:40 PM
2 kwik
I ♥ Acer
2 kwik's Avatar
take out your dremel and do a lil work on the stock one..also they made what is called a double valve cover gasket to help with clearance
2 kwik is offline
Old 07-02-2006, 11:13 PM
greenstreak9205
i was actually gonna try the dremel work and double gasket but wasnt sure if that would be good enough. have you already tried that or was that just a suggestion?
Tivo304
08-28-2023 12:19 PM
vincep99
08-30-2015 11:42 AM
92 5.0stang
08-13-2015 06:46 AM
91LXstanger
04-05-2005 05:01 PM
baddass92gt
02-25-2005 11:49 PM
Quick Reply: clearances
