Throttle body water lines?
I noticed on my car a few months ago that two lines (that looked like the went on my TB) had bolts stuck in them so they were bypassed. I hooked them back up, not knowing any better.
A guy on here said that it makes the intake charge alot hotter, and that by bypassing the hoses together will gain hp (or atleast make it run a bit better).
Has anybody had experience with this? Any advice?
It makes sense, but I was wondering if any of you guys have done this. Is is worth bypassing or should I just leave it like it is?
RE: Throttle body water lines?
ORIGINAL: Jaggezz
ORIGINAL: BCP
Bernie is right, if the EGR and smog stuff is still hooked up then you will be losing hp cause there is nothing cool the recircualted exhaust gasses. If the EGR stuff is no longer fuctioning (air tube, smog pump etc disconnected or removed) then you could leave the coolant lines off of the EGR spacer and hooked to each other.
ORIGINAL: Jaggezz
Reread your post.
ORIGINAL: Jaggezz
You mean if it still ISNT hooked up?
Reread your post.
ORIGINAL: BCP
ORIGINAL: Jaggezz
Reread your post.
ORIGINAL: Jaggezz
I have a FAQ on my site. I would copy it here, but I am too lazy to reformat.
Here... http://www.freewebs.com/vristang/50e...sequipment.htm
You are better off hooking the coolant back up to the EGR spacer.
jason
I also heard that you are supposed to plug the lines... basically someone told me that its making your air alot hotter considering you have coolant flowing through everything.... Just what I heard
