3rd belts replaced need help
Old 08-11-2006, 12:37 AM
1badblue50
1badblue50's Avatar
Default 3rd belts replaced need help
I keep cutting the belt when it rides the Air condition pulley. Does anyone know what can be going on. I have a smog pump delete. I was thinking if i can get rid of the smog pump delete and get a shorter belt, could that work?
1badblue50 is offline
Old 08-11-2006, 01:35 AM
black89gt
black89gt's Avatar
Default RE: 3rd belts replaced need help
yeah you could get a short belt, but you will have route it a different way. i think the part number is 850k6.
black89gt is offline
Old 08-11-2006, 10:35 AM
1badblue50
1badblue50's Avatar
anyone know wich way to route it?
Old 08-11-2006, 11:19 AM
7upedition
7upedition's Avatar
have you inspected the pulley for any burrs or dig marks that may shread a belt up, have you been using belt conditioner? not sure exactly how to route it, lay it out on paper and it'd be easy to figure out.
7upedition is offline
Old 08-11-2006, 12:14 PM
88BlueGT
88BlueGT's Avatar
Are you sure that the rest of your pulleys are lined up properly. Maybe its shredding on your AC because another pulley is off...
I would investigate the problem; not find ways around it.
88BlueGT is offline
Old 08-11-2006, 12:45 PM
1badblue50
1badblue50's Avatar
i think its the smog pump delete pulley. That is why i want to delete the whole pulley.Since i had some one make me the pulley and installed the supercharger the belt keeps moving.
Old 08-11-2006, 12:55 PM
88BlueGT
88BlueGT's Avatar
Than just get a shorter belt.
88BlueGT is offline
Old 08-11-2006, 01:04 PM
redline1991
redline1991's Avatar
not to highjack your thread but, Should I be putting belt conditioner on my belt or will it start slipping or something, sounds like a nebie question I'm sure....lol
redline1991 is offline
Old 08-11-2006, 02:20 PM
1badblue50
1badblue50's Avatar
I understand i could get a shorter belt but the way water pump p/S pump crank shaft and the alternator how low it is i cant seem to get the right angle.
Old 08-11-2006, 02:24 PM
1badblue50
1badblue50's Avatar
Altenator is not there anymore. Its under the smog pump . So if i delete the smog pump pulley the belt would not have a straight run to the A/C pump. just posted a picture of the pulley diagram.
[IMG]local://upfiles/34882/89C977A5F84F4F40841E7DD972341CE7.jpg[/IMG]
5.0muscle
01-11-2016 01:17 PM
9550
10-26-2015 05:01 PM
mrmrultimate
Texas Regional Chapter
09-10-2015 09:43 AM
Blk Vert
09-09-2015 12:16 PM
cbird1177711
09-02-2015 08:51 PM
Quick Reply: 3rd belts replaced need help
