belt squeak!
belt squeak!
I have had 2 belts squeak and i cant get rid of it! i tried the spray but it only worked for a few minutes and then the squeak was back. its a brand new serpentine belt on alum. pullys...I heard of soaking a belt but what do you soak it in?
RE: belt squeak!
same thing happened to me i repalced sprayed did everything and then i replaced the throwout bearing on the clutch and that was the problem could push on the clutch alittle bit and if it stops theres your problem
RE: belt squeak!
Take the smooth sided pullies and take some fine scotch brite and scuff them some. I did this with mine and it stopped the squeeking sound. Like if the water pump pully isnt a ribbed pully, but a smooth pully. Just take it and scuff it up some.
How much can you move the belt up and down? You sure you got the tightest fitting belt for your set up?
autoedit
09-27-2015 06:37 PM
mrmrultimate
Texas Regional Chapter
09-10-2015 09:43 AM
