running rich or lean?
i know my car has no cats so it has to smell a little of gas, but i think its a little to much! actually a lot, does it mean its running lean or rich? and what problems can that cause? how to fix it? maby this can be to my car running like ****?
RE: running rich or lean?
Did it do it before you had no cats? If you just put a mid pipe on with no cats and you just started smelling it its prob just your exhaust. I smell a huge difference just with a SLP catback lol If thats the case its prob just exhaust fumes lingering around....
Well a shop is the only place that can run a full diagnostic on the ecu to see what's causing the problem because it could be a simple as the ecu tripped to as technical as damaged or malfunctioning fuel injectors.
