anyone heard of fiberglass hoods flying up?
Old 09-03-2006, 03:16 PM
randy78045
randy78045's Avatar
Default RE: anyone heard of fiberglass hoods flying up?
Blow me PRO50SC
randy78045 is offline
Old 09-03-2006, 03:37 PM
tinman
tinman's Avatar
Before we all get away...
I think NHRA has something in the rule book about hoods and I think they say that you are supposed to use pins for hoods/decks etc so the starter can see that the stuff is really fastened down.
THIS IS WITH F/GLASS HOODS/DECKS ONLY
An alternative would be Dzus fastners, but I've seen them fail a few times....
tinman is offline
Old 09-03-2006, 03:51 PM
red50stang
red50stang's Avatar
Yes it is a common occurence w/ fiberglass hoods but it can happen w/ any kind of hood. Basically like pro50sc said if your hood latch is not properly adjusted it will most likely happen. But the reason why it happens more often w/ fiberglass hoods is because the latches are fiberglass as well and if you don't get a quality hood it will wear down over time and break causing the hood to fly open. I personally use hood pins because I have a pin on only hood, but if you adjust it right you may not need them but I personally prefer to use them, it's not required just a personal thing, but drag racing does have some stipulations on it.
red50stang is offline
Old 09-03-2006, 04:38 PM
SSKiller
SSKiller's Avatar
ORIGINAL: PRO50SC
The only way it happens is if the hood latch isn't adjusted propperly. I've had one for over 3 years now and never a problem. No hood pins. It's b/c the ppl installing don't know what they're doing.
+1
My hood has been on my car for over 3 years too.........Mine was NOT correctly adjusted and it blew up (thank God for the hood release mech)....so we correctly adjusted it and now I have no problems.
SSKiller is offline
Old 09-03-2006, 05:01 PM
ZachW04Stang
ZachW04Stang's Avatar
My fiberglass hood was supposed to be bolt on but theres no way you could make the factory latch work with the hood. So I just stuck a cheap set of hood pins on and called it a day. Also don't buy from champion fiberglass, there hoods suck.
ZachW04Stang is offline
Old 09-03-2006, 05:04 PM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
ORIGINAL: randy78045
Blow me PRO50SC
That's a job for one of your O/T chickies!!
ORIGINAL: SSKiller
ORIGINAL: PRO50SC
+1
Finally, someone else that knows what they're doin' around here!!![sm=smiley20.gif]
PRO50SC is offline
Old 09-03-2006, 06:21 PM
Pure5.0
Pure5.0's Avatar
Two words.... Zip Ties!
LOL....
Any car's hood can pop up if not adjusted right. Mine is stock and it pops up on the freeway sometimes...thank goodness for the safety latch. I readjusted mine a while ago and still haven't gotten it right.
Hood pins aren't necessary for street use but it is an added security.
Pure5.0 is offline
Old 09-04-2006, 07:21 AM
86 5.0L
86 5.0L's Avatar
hell, my stock metal hood popped open on the freeway and whacked my windshield inhalf...... that was fun.......[&:]
86 5.0L is offline
Old 09-04-2006, 05:13 PM
92frankenstein
92frankenstein's Avatar
I have one that it happened to, however contrary to popular belief u dont need hood pins , they make fiberglass hoods that bolt right on to the stick hinges and latches so as long as that holds up you should be good, cause believe me, its not fun to hit 1st gear hard and see the engine from the driver's seat.
92frankenstein is offline
BOB ROME
07-26-2023 01:54 PM
PaulH2
20
01-31-2016 09:48 AM
11-18-2015 01:34 PM
Urambo Tauro
10-05-2015 09:37 PM
ThatJuanStang
09-25-2015 08:01 AM
Quick Reply: anyone heard of fiberglass hoods flying up?
