OIL PRESSURE-STOCK GAUGE
At start up my oil pressure is slightly above the middle bar on the stock gauge.(Normal)
When cruising around it stays at about the middle(Normal)
When I idle at at light etc..it drops between the two lower lines..not near the red 0 line but the one above it and the next one...so the first and second lines from the bottom.(The middle is the third)
Is that normal or too low.
My problem is I have no history on when this was last rebuilt. If that is ok then I am only going to change my heads and rock on, but if that is too low I will build a stroker.
Thanks
Thanks
RE: OIL PRESSURE-STOCK GAUGE
i had the same problem in my 87. best thing to do honestly change your oil pressure switch, costs like 15-25$ or so and usually corrects the problem.. You probably have normal oil pressure your switch is probably just lying to you. Buy it and pray to god thats the problem cause usually if it isnt that, its bearings and a oil pump.
ORIGINAL: mcuom
Thanks
Thanks
jwog666
12-27-2021 08:09 PM
andrew1969
16
01-08-2016 02:48 PM
