alot of water coming from exhaust
when i rev my car to about 2500 there is alot of water that shoots out of the exhaust. also it is more water coming out the right exhaust.
i also have an o/r h pipe if that changes anything.
RE: alot of water coming from exhaust
Its just condensation built up in the exhaust! Nothing to worrie about. It will do it more if your car sits for a long time. You need to let it run long enough to get it out each time though. Happens alot if you just use your car for short trips and then park it.
are you sure becuase ive never seen anything like this. i mean yeah i know water drips out but this is more than i ever saw. Just making sure its alright, but ill take your word for it.
More than likely the drainage holes in your mufflers are plugged up (more so in the right side) and are just spitting the water that would normally drain out the mufflers out the tailpipe. I wouldnt worry aboutit unless youre blowing LOTS of white smoke out the T-pipe.
-P.
-P.
i agree with the others it's most likely condencation, but if your realy worried about it take a small drill bit and find the drain holes in mufflers and clean them out
SterlingStunner
5.0L V8 Technical Discussions
09-04-2015 06:28 AM
91StangOwner
08-20-2015 11:34 PM
