toploader
RE: toploader
You will need a bellhousing to match it up. I have a TKO500 and I belive it uses an old top-loaded bellhousing, but I bought a new one. I think you MIGHT be able to use a bellhousing from one of the old SROD 4-speed early 80's 5.0's but double check me on that before you $$$.
RE: toploader
ORIGINAL: ih8chevy
would u say that the 4 speed is worth it or should i stick with the 5 speed wci t5
RE: toploader
ORIGINAL: PJB
I sure wouldnt want to lose overdrive. Id look into an aftermarket tranny.
If this is a strip only car it wouldn't matter, he needs to clarify, if its strip only...Stalled C4 with a tranny-brake and cooler and never look back.
