First track run this coming friday...need some advice!
#42
RE: First track run this coming friday...need some advice!
ORIGINAL: ModularFox
why because i can drive my car to a ET almost as quick as yours only mines bone stock with 200K miles, but without all spending all that money on mods like?
ORIGINAL: OnyxCobra
thats retarded advice
id say get some slicks before then, take a trailor with you, limiter launch it and powershift the **** out of it at 5300 RPM. That will get you the ticket to a 13 second pass with a stock 5.0 five speed. Youll get a few good launches before you have to say peace out stock axles
and how is your car bone stock with all those mods you listed?
#43
ORIGINAL: OnyxCobra
No, b/c thats dumb advice to give someone that's never been to a track before and wants to drive his car home.
ORIGINAL: OnyxCobra
i know, i said in a previous post i should have clarifyed myself, the motor is bone stock, the car i guess you could say isnt.
#44
ORIGINAL: OnyxCobra
ORIGINAL: OnyxCobra
#45
ORIGINAL: aode06
Ive seen foxes, do some neat little things to shred off a few tenths
0. pack of ice on top of engine
1. remove your hood.
2.remove your hatch
3. set rear tires to 20 psi and fronts to 40 psi to put weight on the rear wheel s .
4.dont over rev, only use what you need in each gear .
5. once you hook punch it.
6. relocate battery to rear
7. make your pass while car is cold not warm.
8. bump timing up to 16 degrees and run 93 octance.
9. Only have 1/4 tank or less of gas.
10. remove passenger and rear seat.
11. run car 2 quarts low on oil to reduce windage on crank.
12.remove sway bar
13.aluminum driveshaft reduces rotating mass, borrow a buddies or from someone on here, 10 min swap
2.remove your hatch
12.remove sway bar
#46
#2 is good because you def want as much weight as possible off the rear wheels on a rear wheel drive car ... Also alot of tracks wont let you run if you dont have a hood(atleast in VA)
bryan616fl
01-25-2019 09:07 PM
Faolan65
Arizona Regional Chapter
08-25-2015 09:24 AM
