headlight problem
Old Nov 2, 2006 | 12:41 PM
92whitelightning's Avatar
92whitelightning
Default headlight problem
I have a 92 gt and i think that my headlight dimmer switch is shot. When i turn on my dash light switch to engadge the headlights my dash lights turn on but no headlight....the only way that i can get headlight is if i hold down my flasher on the dimmer switch and then that only shines high beams...what do you guys think that my problem is
Old Nov 2, 2006 | 12:59 PM
Hawk's Avatar
Hawk
Default RE: headlight problem
Sounds like the headlight switch to me too. Same thing happened to me and thats what it was for me. Blueovalindustries sells a brand new motorcraft headlight/foglight switch for around $50. You may also want to look at the harness plug that connects to the switch and see if it is discolored/has overheated. Blueovalindustries also sells a replacement harness connector that you can solder in with some bigger gauge wire to help prevent the overheating in the future. Thats around $10 bucks and might be well worth it to you. Hope that helps.
Old Nov 2, 2006 | 05:29 PM
89GTRed's Avatar
89GTRed
yep sounds like the switch is toast. Make sure you get it fixed b4 it burns out any more of your wiring harness. Could get pricey if you dont take care of it soon.[>:]
Old Nov 2, 2006 | 06:09 PM
2 kwik's Avatar
2 kwik
I ♥ Acer
aw hell just use a toggle switch
StalkerGT
Nov 28, 2015 03:09 PM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
ccdguy
Sep 19, 2015 05:20 PM
Mobiusone stang
Sep 7, 2015 08:46 PM
amandahchase
Sep 3, 2015 10:09 AM
