Oil pressure problem HELP
So my dad bought a 94 vert a while ago and it has 72k on the clock, nice ride. Yesterday we drove out to my grandpa's farm and the oil pressure was just fine, but on the way home the guage went a little bit below the N in NORMAL from the R that it usually is at. It has stayed there ever since when we start the car up. Oil level is just fine, I'm wondering what the problem is if any, bad relays or oil pump or what? What would cause a drop if oil isn't leaking and car is bone stock.
RE: Oil pressure problem HELP
That's hard to answer. best suggestion I have is to get a mechanical oil pressure gauge and install it in place of the stock unit and see what the actual oil pressure is at idle and at higher rpms. you could also get a shop with a gauge to measure it for you but you could probably buy the gauge for about the money the shop will charge you to do it for you.
zanemoseley
09-06-2015 12:58 PM
