To expose my ignorance... Balancer
Old 01-06-2007, 07:10 AM
Skyler5.0
Skyler5.0's Avatar
Default RE: To expose my ignorance... Balancer
[sm=jawdrop.gif]that about sums it up
Skyler5.0 is offline
Old 01-06-2007, 07:20 AM
iceman89gt
iceman89gt's Avatar
just had to see how it worked didnt he. hes really in trouble if he starts moding
iceman89gt is offline
Old 01-06-2007, 02:58 PM
LTnone
LTnone's Avatar
ORIGINAL: iceman89gt
I am modding, genius
LTnone is offline
Old 01-06-2007, 03:06 PM
CrazyCobraSpeed
CrazyCobraSpeed's Avatar
nice mod... removing hte engine is a good idea... gets rid of all that weight.... haha i thot i would be a smart *** ... i do like the green color your car is tho
CrazyCobraSpeed is offline
Old 01-06-2007, 05:11 PM
Li0nHart
Li0nHart's Avatar
hope you labeled all your wires...moust plugs only fit one way but you could turn em 180 and push real hard...
.....just kiddin
Li0nHart is offline
Old 01-06-2007, 07:09 PM
LTnone
LTnone's Avatar
Isn't that what duct tape is for?
LTnone is offline
Old 01-06-2007, 07:22 PM
Tims 88GT
Tims 88GT's Avatar
Why do you have the motor pulled?
Tims 88GT is offline
Old 01-06-2007, 11:06 PM
Twisted
Twisted's Avatar
ORIGINAL: LTnone
When I pulled my harmonic balancer off I had the engine at #1TDC, but ended up having to rotate the assembly and now am unsure how the balancer was positioned. When the engine is at #1TDC, should the mark on the balancer be at 12 o'clock?
common sense [sm=icon_beat.gif] me
Balance this.
Twisted is offline
Old 01-07-2007, 01:26 AM
MACDRIVE
MACDRIVE's Avatar
ORIGINAL: mattdel
the balancer is key'ed, can only go on one way.
Yep, there's a term for that, it's called sailor proof .
MACDRIVE is offline
Old 01-07-2007, 01:55 PM
LTnone
LTnone's Avatar
ORIGINAL: Tims 88GT
Heh that's the fun part- I was following directions instead of common sense, and the thing didn't say to remove the lifters before removing the cam. Probably due to it being 2am and I had been working all day I completely overlooked it until I realized that the cam passage was blocked. I had a lifter removal tool that was doing well, but my genius friend decided to try to get one out with his hands. It got removed, right into the oilpan. At this point, with the engine already stripped down to the short block and since I needed to install a clutch/motor and trans mounts, I figured it'd be easier to just yank it out. Easier to put stuff back on while it's out anyway.
Edit: I'm installing pretty much everything in my sig, btw
LTnone is offline
mtgldr
02-03-2024 09:00 PM
jessicarabbit
09-25-2015 12:41 PM
LivingInThePast
09-16-2015 12:20 PM
09-08-2015 11:50 AM
09-01-2015 08:16 PM
Quick Reply: To expose my ignorance... Balancer
