spots in tires
spots in tires
well my 5.0 has been sleeping for the winter, i just took it out around the block a couple times to keep it runing and i notice its thumping which would meen that i have spots in my tires, is there anyway i might be able to fix this or is the only option to buy new tires?
RE: spots in tires
Ouch...new tire time. That's why you want to move the car every two weeks or so, or put junk tires on it for a long storage period. Tires show signs of flatspotting after a surprisingly small period of time.
RE: spots in tires
I should have mentioned that...a minor case should go away with driving, depends on how bad. I had a set sit on a car for 4 months over winter, crappy set but they got it real bad and no amount of driving got rid of em. Give it a try
RE: spots in tires
put it on jackstands ALWAYS if its gunna be sitting for a week or more
as for the flat spot.. did u use the e-brake at all?
im sure its only 1 tire.. bring the car in for a rotate/balance and ask them to identify flat spots in the tires and u should replace them.
jwog666
12-27-2021 08:09 PM
KingRando
10-02-2015 08:06 AM
