Wheel Hop. What should i do?
RE: Wheel Hop. What should i do?
arent lift bars control arms? if so i already have steeda lower contrl arms and a steeda HD sway bar. if those southside lift bars are different ill look into that.
ORIGINAL: tortugasmoker
http://www.livernoismotorsports.com/...t.phtml?p=1072
ORIGINAL: larsif
It appears that they are different because they allow you to mount the barslower than the standard arms on the rear end hosing. Apparently this helps control wheel hop.
dont forget to replace the upper control arm bushings
they are located on the axle. if you havent done that already
you might have to take a torch and melt the oem bushings
out of there and replace them with the new ones. also
look in to a good set of adjustable rear shocks
like kyb agx series or tokico
Livernois is like 3 miles away from my house. Im thinking about getting my car tuned there in the future.
ORIGINAL: larsif
jwog666
12-27-2021 08:09 PM
mungodrums
09-28-2015 10:54 PM
