Spark Plug problem
Old Feb 21, 2007 | 04:24 PM
CarJway's Avatar
CarJway
Default RE: Spark Plug problem
Before you start throwing parts at a car; Why is the check engine light going off? That should be the FIRST thing you do before buying parts. I don't know how to pull the codes on a 2.3, but figure out whats throwing the light (pay someone to read the codes! Then chase down the problem!)
Old Feb 21, 2007 | 05:07 PM
getafewlives's Avatar
getafewlives
When i ran the tests with the code reader i got code 224: 1,2,3, or 4 ckt failure. In the manual code 224 says: irratic idm input to rprocessor. The new coil gave the exact same problem as the last one. So I'm quite sure the is futther back than the coil, what ever controls the coil. And i know forsure that the check engine light is directly related to when the coil works properly or not. When its on and i check the spark on the right coil only 2 plugs have spark, when its off all 4 work. Any help is appreciated, i dont know a lot about cars and im kinda learning as i go. thanks
Old Feb 22, 2007 | 04:35 AM
getafewlives
Hmm well as far as i can figure out im pretty sure its my ignition control module thats gone, which would also explain why my tach doesnt work. Is there any way to test the module forusre? I dont want to replace the module if its not broken. The module at my work is 150$ which is almost at cost. THe model number it gave was lx 230. Does it have to be this exact same one? what do i look for when im getting a moudle? Is there any place to ge tone on cheaper? I looked on ebay but i dont know which ones would work and which wouldnt.
Old Feb 22, 2007 | 04:37 PM
getafewlives
bump
Old Feb 22, 2007 | 04:51 PM
mattdel's Avatar
mattdel
your the guy with the tach that only works sometimes, right? yah that IDM code, and now this.... hmmm............. I'm gonna do some research for you tonight, after work.
Old Feb 22, 2007 | 08:38 PM
getafewlives
thanks dude, i'm still in highschool and this is my first car and i dont want to be blowin money on more parts that dont need replacing.
Old Feb 23, 2007 | 07:08 PM
getafewlives
no ideas yet?
Old Mar 28, 2007 | 06:24 AM
getafewlives
Spark problem fixed. it was the ignition module. Tach still doesnt wanna work most of the time but whatever. All 8 plugs fire so im happy.Got the module off ebay for 30$. thanks guys
Old Mar 28, 2007 | 05:15 PM
88blackgt's Avatar
88blackgt
damn wish i would have seen this earlier. i had the same problem on a buick, tried several coils and it ended up being the module.
articman
Jun 21, 2018 11:45 PM
Emblazoned
Sep 3, 2015 10:45 PM
5.0 kevo
Sep 3, 2015 06:24 PM
cbird1177711
Sep 2, 2015 04:12 PM
