Temp Gauge acting crazy...wtf
My temp gauge is acting crazy lately, I says im overheating, but when i turn the lights off it goes down to normal. ?????? wtf. Im getting an aftermarket pillar gauges shortely but, wtf.
RE: Temp Gauge acting crazy...wtf
ORIGINAL: Joel5.0
....you have a ground problem, you might want to check the ground strap behind one of the cylinder heads that goes connected to the firewall....
Do the following....hook a digital voltmeter to the temp sender wire and battery (-), start the engine and check voltage.....check the reading....turn all the accesories on (headlights, wipers, A/C or blower, press brake pedal) and check the voltage difference....turn all accesories off and check what difference in voltage you read....if the difference is greater than .2vdc (acc. on/off), you have a ground problem.
jwog666
12-27-2021 08:09 PM
