Starting trouble...
Starting trouble...
Hey guys, I just replaced my radiator 30 mins ago. Everything went perfectly. There was no problem whatsoever, until I went to start the car. When in theon position, everything is fine; fuel pump turns on, radio turns on, lights and everything else works. The engine will not turn over, or even click as it does with a poor battery connection. It's as if I am trying to start the car without depressing the clutch. I cannot figure out what is going on. I did connect back all the electrical plugs, the battery terminal was tightened back up good. Anything I might be totally forgetting? Or anyone with a similar experience. It doesn't sound like it has anything to do with the radiator swap, but it would bea pretty wierd coincidence. Any help appreciated.
RE: Starting trouble...
why did you unplug them?
ORIGINAL: 94GT5.0
Well the harness for the fan i disconnected but there were two other harnesses i needed to unplug along with that one. Not sure what they are for tho. Maybe ill try resetting the system?
dalefrancis88
09-11-2015 07:15 AM
