Just Got A 351W-400ci Motor!!
http://www.projectbronco.com/Technic...e_build_up.htm
http://www.projectbronco.com/Technic...the_rumors.htm
read those. your cam and valvetraindesides weather yore gonna have a torque monster motor or a high rpm scream. it designates youre power band more then any other part in the motor. change the cam. change the power range. them's are good motors and there are alot of myths out there about them. but untill you have worked on one or built one dont knock it. they arent that expensive to build if you know what you are doing and looking for.
gtxracing, look on the block and see if u can find a casting number the 351 m casting number is D7TE orD8TE.
oh and the parts from thecleve that are interchangable are as follows
http://www.fordcobraengines.com/Modified%20History.htm
everythin in there is what u will need to read, u might need a new k member if u use the motor and new motor mounts and a cross member for the tranny ur gonna need. i dont kno for sure though
well so does the cleve but if u get the right bellhousing u can mate them.
so if it dont then im sorry
ORIGINAL: VigCS
No, it wont bolt up. The M series motor uses the big block tranny bolt pattern.
Where on the block am I looking for this 351M? Also I'm leaving at 1:00pm which is a few minutes to go check out the motor again, this time writing all the numbers down as I can to reaserch this motor
ORIGINAL: gtxracing
Anyone selling a 351W? I got a bad feeling after looking at that identical pic of the motor, than it is a 351M(ajor *** ****ing) motor. I was offered $400 for the 351w modified 400M so looks like I would have been taking an *** ****ing on that one. I couldn't get in because the guy wasn't there to open the gate but I have the bubble guts over this.
