Running Rich?
RE: Running Rich?
ORIGINAL: ohsoquik02
to rich will cause hurt in performance by a great amount. but yes rich is safer
RE: Running Rich?
Is your coolant temp sensor working? Maybe your car isn't going into "closed loop" mode and thus it (computer) is ignoring your O2's input. Thermastat stuck open? or removed recently?
Yes, you can have codes that do not turn on the MIL. I'm currently tracking down a Thermacter Air problem [:@] the codes keep setting but does not turn on the MIL.
RE: Running Rich?
that system is the smog pump system reduces the hydrocarbon and carbon monoxide content of the exhaust gases by allowing the combustion of unburned gases to continue after they leave teh combustion chamber. elimintating or bypassing the engines air injection pump is illegal in all 50 states in any vehicle registered and or operated on public roads. this pump on a 5.0 ho draws approximately 3 hp.
ORIGINAL: bobby
???? ANYONE?
???? ANYONE?
ORIGINAL: bobby
what is the thermactor air system? i keep getting that code too, that is the only one....... does it matter if it is working or not?
