Shift Light Install
Shift Light Install
I tried searching but i couldnt find anything on this exact topic. Where do i plug the green wire from a shift light into? I read that you have to tap into the wiring harness on a 98... is this necessary for a 89? THANKS
RE: Shift Light Install
When i put mine in i hooked it into the distributor, on my 90 5.0 there is a connector with a plug right off the distributor wires. i took off the plug and put the wire into it, it works so i wired it into that.
ORIGINAL: blkonblk5.0
Soldier GT
12
08-20-2015 09:42 AM
