removing iac
Old Apr 7, 2007 | 10:00 PM
Streetracer911's Avatar
Streetracer911
Default RE: removing iac
I didn't remove mine I just made a plate for it like this
Old Apr 7, 2007 | 10:04 PM
Streetracer911
heres a pic of the iac. If you can't find it then you must not know ANYTHING about cars.
Old Apr 7, 2007 | 10:09 PM
AndySpeed's Avatar
AndySpeed
no no i know were it is.. i duno what i was thinking.. but so how small would u make the resricter plate? someone should do a write up on this one.. sounds like its a very easy and interesting thing to do.. street racer you got the specs on ur plate? id love to try this with my new procharger setup i think thatd sound completely sick ..
Old Apr 7, 2007 | 10:18 PM
dman302's Avatar
dman302
Why in the name of GOD would you want to delete that item? I would serve no advantate at all. A restictor can sometimes be used to moderate a poor idle...but removing it is just as rediculous as anything I've heard. Majority of the time a restrictor plate is used to 'bandaid' another problem in the systme like a vac leak or EGR issue that has not be rectified...unmetered air causes idle instability and the plate simply restricts flow to allow the IAC to stabalize the idle a touch better. More often than not they don't work properly simply because the true cause is not corrected and the plate is unable to assist as it was designed.
Old Apr 7, 2007 | 10:29 PM
Streetracer911
ok Andy this is what I did and solved the issue 100%
Locate your IAC which will be on the passenger side of the car and is attached to the throttle body.
Unplug the wire that goes to the IAC motor and remove the two 8mm bolts.
Get a piece of sheet metal around 0.027†thick. You can use steel or aluminum it doesn’t matter
Using your old gasket trace it onto the piece of sheet metal. Trace all of the holes as well.
Cut it out with a pair of tin snips.
File down the sides so there is no sharp edges.
Drill out the holes you traced. The one big hole you will want to drill with a 5/8†drill bit. The other hole you will want to make a small hole. Start with a 5/16†(drill in the center) drill bit and keep moving up if it is hard to start cold.
File down those holes as well so there are no sharp pieces.
Put the plate on so that the small hole is facing towards the passenger side.
Put the new plate on first and then the gasket. The gasket should be on the throttle body and the plate should be against the IAC.
Put the two 8mm bolts back in and tighten to spec. DO NOT OVER TIGHTEN
Connect the wire back to the IAC
Start the car up.
If the car doesn’t start take the IAC back off and do the whole process again using the same plate, just make the hole bigger. Keep doing this until the car idles nicely and RPMS drop quickly.
Old Apr 7, 2007 | 10:55 PM
house302's Avatar
house302
i am doing it because mine is shot and i dont feel like spending alot of money to replace it. i want to find out if that is what is making my throttle body whistle. i have been on here alot to get ideas for what is causing the whistling in my throttle body. On mustangsunlimited.com they said if you are getting a whistle then your iac needs to be replaced. they were selling them for 121.00 and i dont want to spend that kind of money. so if people are questioning me thats why i am doing this.
Old Apr 7, 2007 | 10:56 PM
Streetracer911
house good luck with that. It is a pain in the ***
Old Apr 7, 2007 | 11:37 PM
dman302's Avatar
dman302
My BBK whistled..by PP tb whistled, my other BBK whistled. Don't rig your car to save a few bucks...if it doesn't run correctly FIX IT buy one used, or maybe I don't know...maybe....clean yours. TB whistles are as common as canadains with colds.
Old Apr 8, 2007 | 02:10 AM
5.0stanger's Avatar
5.0stanger
ORIGINAL: house302
I got a new one from NAPA for $56. What is wrong with yours?
BOB ROME
Jul 26, 2023 01:54 PM
jwog666
Dec 27, 2021 08:09 PM
Dathan
Oct 5, 2015 05:52 AM
jrrhd73must
Oct 2, 2015 09:17 PM
lmurf60
Sep 24, 2015 10:07 PM
