thermactor problem.
Old Apr 8, 2007 | 06:06 PM
onebad88's Avatar
onebad88
Default thermactor problem.
alright, i ran my codes to try and pinpoint some of my problems. well with the KOEO test i got code 63-TPS voltage too low, but i just adjusted it the other night. it was at like .58 volts and i had to drill it and gt it to.99. at wide open i was only 4.68. for the KOER test i got 94 and 44 which are problems with the thermactor air control system. now my smog pump's plmbing is removed but the tuing connecting the heads is still there and is open on the end, should removing that and plugging the holes solve that problem, and i know the length for the belt for no smog and a/c is 74.5 w/underdrive pulleys but what is it with stock ones. thanks for all the help so far guys.
Old Apr 8, 2007 | 06:31 PM
HC_CrAzYHoRsE's Avatar
HC_CrAzYHoRsE
Default RE: thermactor problem.
the tube needs to be plugged, or you can remove it and plug the heads yes, just don't leave it open!
Old Apr 8, 2007 | 06:33 PM
onebad88's Avatar
onebad88
do you know the size of the bolts
Old Apr 8, 2007 | 06:39 PM
HC_CrAzYHoRsE
5/8 but they're a PITA to thread in, i just cut the connectors on the thermactor line, flipped them around, applied some RTV and screwed them back in.
Vrooom
Feb 21, 2016 05:25 PM
69Volunteer
Sep 30, 2015 10:39 AM
bconboy
Sep 24, 2015 01:55 PM
mdj89
Sep 23, 2015 08:49 AM
ccdguy
Sep 19, 2015 05:20 PM
