84 -5.0-Stang fuel pump wiring NEED HELP
Cant find where my fuel pump is fed voltage from,pink power wire goes from pump in tank to pump on rear passanger frame,shutoff switch ok,cant locate fuse if there is one. need to get to work and have no running vehicle and live way out in woods,also does the pump run when you turn on the key and continuously run till key is shut off? can i run a hot wire on switch?please help, Thanx.
RE: 84 -5.0-Stang fuel pump wiring NEED HELP
ORIGINAL: ron1234
But seriously did you contact the local auto parts store or dealership?...They should be able to tell you...Not being rude but i would think they could help. Let me break out my Chilton's book and i will try and get an answer for you in the next few hours..
ORIGINAL: ron1234
no after a few seconds it shuts off after the pressure is built up
WRONG! once the engine is running it runs continuously and the fuel pressure regulator by-passes excess fuel back to the gas tank.
not sure about the '84 but in my '88 there is a fuel pump relay mounted under the driver's seat which could have failed on you and that's why the pump wont' run. if it ain't there on the '84, I don't have a clue where they hid it, sorry.
jaiidutch
09-14-2015 10:29 AM
