Any ideas?
RE: Any ideas?
ok im lost is it the holley or stock intake? if it is stock get a new intake like mattdel said. But if its a the holley the only thing i see you doingeither replacing the intake, or tig welding alumium and retaping the hole ( taking it off the motor of course) and if that the holly that sux bro sorry
RE: Any ideas?
I crossthreaded a bolt on the passenger side of the fuel rail. Didnt have anything to drill it out and retap at the time so i got creative. To make sure the injector stayed in, i used a zip tie to hold the rail down by threading it under/over the coolant lines next to it. It stayed without the zip but i figued it wouldnt hurt.
Zip tie or the rail hasnt moved in 2 years.
Edit - when i say crossthreaded i meant it snapped the head off, flush with the bolt hole.
RE: Any ideas?
ORIGINAL: Blckstng93
RE: Any ideas?
i was messing with it 2day and the number 2 injector is spraying from where it connects from the fuel rail to the injector, i have 24lb injectors, i believe the fuel rails r stock would that cause a prob, i dont see any cracks in the rail though
RE: Any ideas?
take it out again and check the o-rings for damage, and check for something stuck in the rail port. the pressure is pushing past the designed functionality of the rail, so something is broken or not cleaned properly.
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
