I've noticed on working on new and newer cars thatthe throttle is a lot easier to push. On both my Horses (Stang & Bronco) the throttle is kind of stiff. Sort of hindering the throttle response so to speak. What can a guy/gal do to help free things up a bit besides, lubing up the throttle cable, throttle body, maybe take out a spring or weaken it, but that may result in disaster down the road, huh?
whats the difference between the cable and the wire? just thinner?
ORIGINAL: thelast50ho
alot of newer cars have throttle by wire which is why they are easier
ain't you never heard of "fly by wire"?? it means there are no mechanical connections between the control devices and the devices being actuated, everything is done by computer signals through wires to motors, solenoids, hydraulic valves, etc. that in turn move what needs to be moved.
You may need to lube/replace your throttle cable, i noticed when i replaced my TV cable my throttle was alot smoother. I might even get a new throttle cable too.
