Alternator Problems????
Old 05-11-2007, 07:14 PM
1990boostang
1990boostang's Avatar
Default Alternator Problems????
I just had my alternator tested and it was good. So i went and got new plugs for it. Its still not charging . It just all the sudden quit but the alternator is still good WTF.
1990boostang is offline
Old 05-11-2007, 07:18 PM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
Default RE: Alternator Problems????
Wiring/short problem most likely. Have you checked the power feed wireto see if it has power?
PRO50SC is offline
Old 05-11-2007, 07:19 PM
1990boostang
It has powergoing tothe alternator. I started it just now and unplugged the battery and it died.
Old 05-11-2007, 07:20 PM
P Zero
P Zero's Avatar
Does the guage on the dash show its charging? Some cars have will cut out if the alt. is unplugged. Never heard of it happening on a stang but its a possibility.
-P.
P Zero is offline
Old 05-11-2007, 07:21 PM
drhoward
Penis Mod Erator
drhoward's Avatar
maybe you have u/d pullies and don't know it
actually that happedned to me when I first bought my 94 I couldn't figure out why my battery wasn't charging when I wasen't accelerating[8D]
drhoward is offline
Old 05-11-2007, 07:22 PM
1990boostang
Its not charging anything the gauge is almost at the bottom in the red.
Old 05-11-2007, 07:29 PM
1990mustanggt
1990mustanggt's Avatar
You have a wire that plugs into it, I think it is black with an orange stripe. That wire has some little fuse looking things that run in line on it. Check those. They could be blown. I had the same problem with my friends car once.
1990mustanggt is offline
Old 05-11-2007, 07:34 PM
Derf00
Gentleman's Relish
Derf00's Avatar
ORIGINAL: 1990mustanggt
You mean a fusible link. That's a possibily, or the alternator is bad and the tester just didn't show it. There is such a think as undercharging.
Had a similar thing happen to me where my cars lights would start dimming and the battery light (charging light) on my car would start flickering at WOT. Bench test of the alt. show'd 3 good tests and two bad tests. I replaced the alternator, no more flickering or lights dimming. This was on an '00 V6 manual.
Derf00 is offline
Old 05-11-2007, 07:52 PM
stang8689
stang8689's Avatar
could it be a bad battery
stang8689 is offline
Old 05-11-2007, 09:12 PM
lookin4astang
lookin4astang's Avatar
Could be. Check it with a voltage tester. Check the plug ins on the alternator as well. They are notorious for failure. Only $7 at your local partshouse if you do need one. Check both black/orange wires, and the fusible link is right under the starter solenoid. It will be on a dark green wire. Check that. The car *should* still run if you disconnect the battery. So if it isn't, there is a problem either with the alternator or your wiring.
It's a simple fix. Just check your wiring carefully.
Here. This will help.
lookin4astang is offline
jma2
07-10-2023 01:00 AM
Golfsito
10-06-2015 11:02 AM
Big Al's 03
Mach 1 Section
09-21-2015 07:59 AM
ccdguy
09-19-2015 05:20 PM
mrmrultimate
Texas Regional Chapter
09-10-2015 09:43 AM
Quick Reply: Alternator Problems????
