Coolant Leak - Noob
Old 06-02-2007, 04:14 PM
92 50's Avatar
Default Coolant Leak - Noob
I just picked up a 5.0 and have a coolant leak already thanks to the place that balanced my tires. Anyway I believe it may be from the heater core but there is a line covered with coolant below the vehicle.
I have no coolant in the car right now and just wanted to know how much to put in, since I don't have owners manual. Also which place do I put the coolant in? I'm assuming the one cap that says coolant and has the sensor is an overflow or do I put in directly in the radiator.
Help this newb out.
Dave
92 50 is offline
Old 06-02-2007, 04:18 PM
86 5.0L
86 5.0L's Avatar
Default RE: Coolant Leak - Noob
hehehe, im assuming you dont have alot of experience with working on cars so.....
if theres no coolant then place your water hose all the way in thru the radiator, let it fill and overfill, if the water is not clear keep it there for abit, where is the line that is covered in coolant? the heater core is under the dash so if that leaks t would leak inside the cabin.
86 5.0L is offline
Old 06-02-2007, 06:13 PM
92 50's Avatar
I actually am going to correct myself, there is not a visible leak now...
I do believe I am out of coolant so what steps do I take to assure this and do I just do 50/50 coolant and water when filling her back up? I just fill it up until it is full correct?
92 50 is offline
Old 06-02-2007, 06:21 PM
86 5.0L
86 5.0L's Avatar
first off just use straight water until you figure out where its going[&:]
86 5.0L is offline
Old 06-02-2007, 07:01 PM
92 50's Avatar
what do you mean where it is going?
92 50 is offline
Old 06-02-2007, 07:14 PM
88redhatchgt
88redhatchgt's Avatar
What he's trying to say is water just dont evaporate ove a couple of hours. Put a hose in the radiator and fill it up start your car then see if you can find out where it is leaking from. Because the water is going somewhere,If its not leaking on the ground or inside your car on the floor and it runs out again.Look for some nestle quik in you oil.
88redhatchgt is offline
Old 06-02-2007, 07:27 PM
5pointslow91
5pointslow91's Avatar
ORIGINAL: 88redhatchgt
lol been there b4
5pointslow91 is offline
4cylinderplus2
10-09-2020 07:45 PM
bradleyb
11-27-2015 07:50 PM
jerrytubes
10-23-2015 12:11 PM
bradleyb
California Regional Chapter
10-01-2015 01:02 AM
wraith777
09-28-2015 10:49 AM
Quick Reply: Coolant Leak - Noob
