Ran codes...got questions
Old 06-11-2007, 02:18 PM
  #21
5.0stanger
5.0stanger's Avatar
Default RE: Ran codes...got questions
So then the third test tells me where my MAF sets as far as being good. Since my voltage is reading high, there could be a chance that my MAF is bad aswelland my computer that says the voltage is low(since it isn't low, but high).
WTF is going on....why would both my ECM and MAF go bad at the same time?? I am confused...
5.0stanger is offline
Old 06-11-2007, 02:29 PM
  #22
Joel5.0
Joel5.0's Avatar
No need to be confused.... ..........once you "warranty" the ECM and install it, code 26 (instead of 66) should be the one showing if the MAF voltage is too high.
Joel5.0 is offline
Old 06-11-2007, 07:34 PM
  #23
5.0stanger
5.0stanger's Avatar
okay, I will wait till tomorrow and see. Thanks again and I will let you know.
BTW, how do you know so much...are you a ford tech? I am pretty impressed with your knowledge, you have help me in the past a few times also.
Old 06-11-2007, 07:53 PM
  #24
Joel5.0
Joel5.0's Avatar
Thanks!.....but nope....no Ford tech here.........but it's what I do every day .....OBD-II, SRS, ABS, TCM's, ECM's, PCM's, GEM's, VATS, Motronics, etc, etc......all brands....Fords are my "babies" though......
Joel5.0 is offline
Old 06-11-2007, 08:02 PM
  #25
tmajikman
tmajikman's Avatar
Joel5.0, you should get your contributor tag, you have helped me out in the past as well, thanks btw.I was not tryingto steal you thread either 5.0stanger
tmajikman is offline
Old 06-11-2007, 08:11 PM
  #26
5.0stanger
5.0stanger's Avatar
no problem..now if I can just get this car running right...
Old 06-11-2007, 08:14 PM
  #27
tmajikman
tmajikman's Avatar
I would try to help, but I know Joel5.0 has it covered, not to mention I do not know my stuff like he does in that area of expertise.
Old 06-11-2007, 11:50 PM
  #28
5.0stanger
5.0stanger's Avatar
I think we got it...just have to wait for parts now.
Old 06-12-2007, 10:35 PM
  #29
5.0stanger
5.0stanger's Avatar
okay, new computer and different MAF...ran car, felt good. Ran codes again[:@]
Got code 56, 66 and 95 WTF?? My voltage is too low and too high?? I checked the voltage on the new MAF and is was the same as the old MAF at idle..too high. I must be missing something
Tivo304
08-28-2023 12:19 PM
9550
10-26-2015 05:01 PM
StalkerGT
09-25-2015 02:41 PM
ctgreddy
09-20-2015 08:35 PM
96stang3.8
09-10-2015 06:42 AM
Quick Reply: Ran codes...got questions
