intake question
RE: intake question
Replace it for sure, definitly hold you back, and if its a money issue just wait to save up a little more, because if your going to have money forheads theres no reason not have some for at least a cheap street heat trickflow intake or find one used.
RE: intake question
Try looking at the Heads/Cam/Intake setup as a system... really should include, MAF, TB, EGR plate in the same breath, but any ways... the heads can only intake and exhaust as much volume as the MAF/TB/EGR/Intake will allow... regardless of cam lift and duration. At the minimum buy a used GT40 Upper/Lower. I'd wait a bit and get it all at once, but thats just me ...
RE: intake question
ORIGINAL: 7upedition
RE: intake question
No,the larger TB will improve throttle response to a point. But yes you can go too big,Ideally you want the MAF to be slightly larger than the TB/EGR/Intake inlet, and you want the TB/EGR/Intake Inlet to be the same Diameter.
For Example: 73mm MAF with a 70mm TB/EGR/Intake Inlet, however a lot of aftermarket intakes are 75mm, so in that case you'd go with a 76mm (C&L Performance) these are highly tunable for different size injectors, so theres room to grow.
For a stock setup I'd go with 65mm TB/EGR... but if i were you I'd just wait and install it all at once
Luke9222
10-22-2015 11:55 PM
