Couple of Questions
Couple of Questions
I just completed my trick flow swap, 24# injectors, 70 MM mass air and 70 MM throttle body.
1. Do I need to do anything with the fuel pressure?
2. Did a search on the idle air control valve and can't find an answer,
Is there a way to clean this part or is one of those parts that has to be replaced if bad?
My car is idling like crap and dies at every red light unless I stay on the gas.
RE: Couple of Questions
you should have an adjustable fuel pressure regulator and set at i think 42 pounds, I have one for sale cheap, pm if interested
the IAC can be cleaned, remove the bottom, 2 phillips screws and soak it in some kerosene.
