Running Better Without my MAF Sensor?
#21
RE: Running Better Without my MAF Sensor?
The problem with my car is that I have trouble keeping my car to idle right but after a few tries of trying to start it without my MAF sensor, the car runs very good. Then when I turn it off, I run into the same problem. I have driven my car with the MAF sensor connected and the car runs horrible. It backfires, does not respond well when I hit the gas and even if I floor the peddle, the car does hardly moves.
#23
ORIGINAL: 7upedition
no the sampling tube is the small diameter tube inside the MAF tube, where the MAF wires are located, a certain volume of air is sent through that siameter and then converted to 0-5 or 1-5 volts (cant remeber) and that is used to determine how much fuel the car needs to maintain a proper A/F ratio... It should be held in with two allen head screws.
#24
Actually yes, the car did not run like a 5.0 but it seemed as if the car got worst over time. A friend of mine disconnected the MAF and the car ran like an animal for a week or so. Thats when I had the trouble of keeping it on. Now I have to play with the MAF sensorby turning the car on and off with and without the sensor until it finally catches on and stays on. But when I finally have the car running, the MAF sensor is disconnected.
#30
doubt it. you need to get a volt meter and start carefully watching your MAF readings, see what its doing. also check the 5v reference signal, its tied into the IAC 5v.
