GT40 INTAKE OR TRICKFLOW
#31
RE: GT40 INTAKE OR TRICKFLOW
ORIGINAL: FullAuto
I'd put a Holley, RPM2 or maybe a Track Heat if you can get a good deal on a used one. If I was buying new, I'd get the Holley or RPM2 though. I don't recommend cams. I recommend not buying a FMS or TFS cam. I know what not to use. I know who to ask for a good recommendation. And I know I'm not that person.
#33
ORIGINAL: FullAuto
I nominate this statement for dumbest statement of the year award.
ORIGINAL: chath_brick
the gt40 is obviously going to flow less, thats what gives it better hp and torque on the low end
#35
ORIGINAL: my77stang
all other considerations aside i think the BBK intake LOOKS the coolest
#36
you obviously have no idea how the physics of air flowing through a tube works, and the fact that your rebuttal was an insult instead of a valid response pretty much means i win...a smaller tube is going to flow air much faster up until you reach the theoretical "limit" of the airflow, meaning a more restrictive intake (aka a smaller tube)is going to flow air faster up until a certain point...if more flow is always better, than why doesnt everybody have a 6" exhaust and a garbage-can sized intake? if you dont believe me, take a small coffee-stirrer straw and a regular straw and blow gently into each one. the air is going to come out of the smaller one much faster. now blow hard into each one. the air is going to be restricted in the smaller one (it will reach its flow limit, like the gt40 at a high rpm) and flow much better through the big one. so basically, the intake you choose should match up with your driving style, you shouldnt be chasing flow numbers.
ORIGINAL: FullAuto
How fast does the air flow through the tube when the other end is closed? There are more variables working here than you are looking at. This is probably a good thing since you still haven't figured out the firststep. You think you actually have a point since I'm the only person who will disagree with you. Take your arguement over to speedtalk or hardcoreand you'd be flamed beyond recognition. You'd probably be banned from hardcore pretty quickly. They don't take kind to spreading of misinformation.
Put in the correct cam for both combos and the TW headed/TFS intake combo will make more power everywhere (low end included) for this application. With either combo, cam timing will make or break the outcome. Your velocity won't mean crap with the wrong cam. And given the correct cam for both combos, the higher flowing combo will run off and leave the GT40 junk. I'm not telling the guy to put on a set of Blue Thunders on his stock shortblock. But in THIS application, if YOU can make more power with the smaller parts, then YOU don't have a clue what you're doing. And I don't doubt that a bit. Keep playing withstraws and leave the motors to the big boys.
#38
wow, there is so much wrong with that arrogant piece of trash of a post, i'm not even going to bother to argue with it. the most glaring point being that he didnt even ask about a cam, he asked about intake vs. intake on his heads. but, apparently i dont know what i'm talking about (OMG TEH HARDCORE BOARD WILL PWN JOO OLOLOLOL!!!!!11!!!!11!!!!1!), but maybe you'll believe this guy:
http://www.tmossporting.com/tabid/3451/Default.aspx
jwog666
12-27-2021 08:09 PM
daltron
04-28-2016 08:10 PM
bradleyb
11-27-2015 07:50 PM
