will this fit
will this fit
will this fit my 92 mustang 5.0 gt with all stock exhaust
FLO-17116
Hear the aggressive sound of American Thunder.
Exhaust System, American Thunder, Cat Back, Aluminized Steel, Ford Mustang, Kit
These American Thunder exhaust systems have been designed with the latest exhaust technology available. Through this technology, you will experience improvements in acceleration, passing power, and fuel mileage. The key to these performance improvements is the use of mandrel-bent tubing. The tubing allows for superior exhaust gas flow, while aluminized steel construction allows for its corrosion-resistant qualities. They also feature a 2-chamber muffler(s) that’ll give you plenty of Flowmaster sound outside the vehicle, as well as inside it. Every kit comes complete with all necessary hangers, clamps, and mounting hardware for an easy installation.
Vendor Flowmaster
Product Line Flowmaster American Thunder Exhaust Systems
Universal No
Exit Quantity Dual
Exit Location Split rear
System Material Steel
System Finish Aluminized
System Style Cat-back
Inlet Quantity Dual
Intermediate Pipe Diameter (in) 2 1/2
Tail Pipe Diameter (in) 2 1/2
Tip Diameter (in) 2 1/2
Quantity Sold as a kit.
Notes OE-style tips.
FLO-17116
Vendor Flowmaster
Universal No
Exit Quantity Dual
Inlet Quantity Dual
RE: will this fit
That is the same system that I had shipped to my doorstep! It sounds awesome, only took an hour maybe 2 to install.. You must saw off your old exhaust that's why, MAKE SURE YOU READ THE INSTRUCTIONS!
RE: will this fit
ORIGINAL: fast83gt
I'm pretty sure that a '92 is a 2.5" exhaust. I think it was either '86 or '87 that they switched from 2.25 to 2.5.
by the way what are you getting for a price on that setup?
The 87/93's never had anything other than 2 1/4" exhaust.
RE: will this fit
ORIGINAL: link1235jeff
so the pipe size from 2 1/4 to 2 1/2 will not make a difference
RE: will this fit
^^^ What he said. But yes it WILL work with your stock exhaust... Bsaically until you get an h/x pipe and some headers, you will only notice a sounds diff, the performance will come with the other things.
RE: will this fit
jwog666
12-27-2021 08:09 PM
BeatnikFink
10-01-2015 08:00 PM
