Head lights/Panel display
RE: Head lights/Panel display
unscrew the steering column covers and its bolted to the shaft support( thats how you get to the multi switch)
be sure to locate the problem first( if you have a voltmeter or a circuit light it will be a lot easier)
so you dont start tearing up all your stuff..( check to make sure that your head lamps are the correct ones, i think stock is 50/55 watts that is, i know cause i bought some that were higher rated and that fried some of my wires)
