final porting questions
RE: final porting questions
ORIGINAL: FivePointOhh
im gasket matching so ther shouldnt be an problem with getting the correct size. imma go buy a measuring tool that way i know im keeping the same diamter throughout the port. i'd hate to bottle neck it or have big open area's and create turbulance
well no, unless that will measure far enough into the intake. otherwise i was thinking more along the lines or like a telescoping tool or whatever they are called. i forget.
Crap, I know what you're talking about, but I don't know what it's called. It looks like a T where the top telescopes out when you twist the handle, so that you can measure the size deep in a port.
telescoping gauge, but you will need a micrometer to use it....or a scale. Try and find some inside dividers, should be cheap and easy to come by at sears. Then you can use a scale to measure off it.
i looked up the telescoping things and its like 150 bucks for 4 of them....no way im spending that much on that. i can make the dial caliper work. either that or ill make a refference tool.
Yeah, the telescoping gauges are expensive, I have a full set for work.
http://www.shoprutlandtool.com/webap...&langId=-1
Look at the inside calipers.
TfcCDR
09-14-2015 12:08 PM
