pedestal rockers???Please help
hey everyone im building a 302 5.0 with my dad..were both lost....The heads i got are set up for pedestal rockers...but how do you perdestals sit underneath(between the rocker and head?) or when i put bolt in through top of rocker...if its through the top seems like the bolt isnt long enough?? please someone help
thank mike[:@]
thank mike[:@]
RE: pedestal rockers???Please help
there should be a rocker then inside it is a removable what I call sled that the rocker pivots on and the bolt goes through the center off it and to keep them centered there is a locking bar that the pedastal sits in for both rockers on that mounting surface on the head
the fulcrum sits on top of / thru the rocker, and the bolt tightens the whole thing down tight to the head. (the rockers should be tight too, unless your pushrods are the wrong length)
ORIGINAL: creekrat
I'm asuming the cam lobe is on the base line instead of at the top of the lobe when you are trying to install this rocker?
BTW, stock rocker arms?
69MustangCoupe393cid
10-03-2015 10:33 AM
JDWalton
09-24-2015 08:47 PM
