stock 90 heads should bolt onto my 85...
Old 11-02-2007, 01:11 PM
DoctorD415
DoctorD415's Avatar
Default stock 90 heads should bolt onto my 85...
So stock heads off a 1990 GT should be able to bolt in place of my stock E5 heads on my 85 GTcorrect? If the 90 is stock there should be E7 heads on it, which can directly replace my 85 heads with no problems or changing of anything. I have to travel a bit to pick these heads up so i just want to be completely sure there goin to work. Thanks.
DoctorD415 is offline
Old 11-02-2007, 01:43 PM
my77stang
my77stang's Avatar
Default RE: stock 90 heads should bolt onto my 85...
everything will directly swap over 100%, but for craptastic stock heads I hope your not paying too much money if your having to drive to get em[&:]
my77stang is offline
Old 11-02-2007, 02:05 PM
dimebag
dimebag's Avatar
that is tru, e7s sucks *****, i have them on the car still,i wish i didnt, i also have a set of them and a set of e6 heads, that im just going to give to my engine perf. teacher to use as demonstration.
dimebag is offline
Old 11-02-2007, 03:55 PM
schwindty
schwindty's Avatar
If you ever run a aftermarket cam just watch piston to valve clearance. If i remember correct those 85's have flat top pistons.
schwindty is offline
Old 11-02-2007, 04:44 PM
83gtragtop
83gtragtop's Avatar
ORIGINAL: schwindty
Correct
83gtragtop is offline
Old 11-02-2007, 05:31 PM
my77stang
my77stang's Avatar
umm, 86's had flattops, 85's shouldnt (i thought) [&:]
Old 11-02-2007, 10:41 PM
DoctorD415
DoctorD415's Avatar
alright, thanks, curious though, do they directly replace E6 heads also? And i just talked to the guy and he said 75 for both. Thats the best offer ive gotten so far.
Tivo304
08-28-2023 12:19 PM
cbird1177711
09-02-2015 08:51 PM
cbird1177711
09-02-2015 04:12 PM
Quick Reply: stock 90 heads should bolt onto my 85...
