1987 Mustang Gt
1987 Mustang Gt
OK i have a 1987 Mustang Gt and i am having some problems with it?
the battery keeps on Dying!
It is Idling wrong on a cold start it idles at about 1500 rpm's which i understand.
But when it reaches water tempeture about 150 it goes to 1000rpms and drops to about 200 and keeps doing that?[:@][:@][:@][:@]
Also having trouble finding the engine oil drain?[:@]
Any suggestions?
Send some photos it would be helpful but if cant just be very descritive
David
Any suggestions?
David
RE: 1987 Mustang Gt
trying cleaning ur iac and getting ur alternator bench tested to see if its charging the battery
iac helps control the idle, cleaners like 4 bucks
helps control air flow when the throttle plate is closed
RE: 1987 Mustang Gt
i agree with ponyboy. sounds like iac is sticking. it is located on egr spacer. its a long aluminum looking cylinder with a two wire connector hooked to it. easily unbolts via 2 8mm bolts. i also agree with checking the charging sytem. if thats ok check for a draw on the battery. let me know how it turns out
RE: 1987 Mustang Gt
also you might have UD pullies which don't charge well anyways in the cold, compare the size of it to a new one at the parts store, an underdrive is bigger than stock
there are 2 oil drain plugs, one in front of the sway bar, one behind
RE: 1987 Mustang Gt
Thank you for your support.it is really helpfuli am having way too much trouble with this car i have rust connecting the windshield to the roof i have rust on the bottom of the door pannel like flaking almost to the inside of the door i need to find sumone to bondo it
NorthAmericanTuning
11-09-2016 11:45 AM
NorthAmericanTuning
03-18-2016 11:21 AM
01-06-2016 07:03 PM
