6A ignition box
Old 03-06-2005, 08:55 PM
stanglx2002
stanglx2002's Avatar
Default RE: 6A ignition box
get a used one on ebay and it is a lot cheaper thats where i got mine
stanglx2002 is offline
Old 03-06-2005, 11:58 PM
90LX50
90LX50's Avatar
ORIGINAL: Wessy
Here try reading THIS. Helped me out a lot.
Edit: It looks like you'll want to get the harness PN 8874. Scroll down and click the one that says "FORD IGNITIONS Wiring a Ford TFI with Harness, PN 8874."
Yep, i got the 6AL and the msd-8874 from summit, it's going to make my wiring it up a breeze.
90LX50 is offline
Old 03-07-2005, 12:09 AM
bobby
bobby's Avatar
ORIGINAL: 90LX50
ORIGINAL: Wessy
msd-8874
how excactly does that wring kit work?
bobby is offline
Old 03-07-2005, 02:04 AM
JaxJags88GT
JaxJags88GT's Avatar
if you get the TFI adapter you dont have to cut wires, dont go ghetto though and put it by your battery like me lol. i of course rewired it and it's under my CAI now. With the TFI you can have it wired in about 3 minutes, mount it under the seat and ground it good.
JaxJags88GT is offline
Old 03-07-2005, 05:24 AM
Dejavu
Dejavu's Avatar
A friend at work says he's going to let me have a 6a that he bought about 4 years ago and i've read and heard all over the place that they are great to have in your car but wasn't sure why- so thanks for the info on that.... and about the built in rev limiter- what does that do? and are you saying that I can also have that as an " add on" on a 6a box, if so, how important is it to have that?
Thanks again guys
Dejavu is offline
Old 03-07-2005, 09:50 AM
bobby
bobby's Avatar
the rev limiter is nce to have built in because then u dont need a seperate box for it. the rev limiter does just what it sounds like it does, limits the RPM's of the motor. if you put a 3k rpm chip in it, u can sit in park and hold the throttle to the floor and it wont rev past 3k. u do this ot prevent engine damage and valve float. for you car i would put a 6k or maybe even less, because your not making power up there with stock cam/heads.
bobby is offline
Old 03-07-2005, 02:50 PM
roundman
roundman's Avatar
ORIGINAL: Dejavu
Thanks again guys
the rev limiter drops the spark to the plugs randomly from cylinder to cylinder to keep the rpms from exceeding whatever the limiting chip is set for so that the engine cannot exceed that rpm for any reason. most people use them to keep the engine rpms from exceeding the red line in the case of a missed shift or a breakage in the driveline which would let the engine rpms go to the moon and then blow up the engine too. they can also be used with a two step limiter which allows you to have two rev limits, a lower one for staging the car or doing the burnout and the other to protect the engine at the higher setting in case something breaks.
roundman is offline
Old 03-07-2005, 08:30 PM
bobby
bobby's Avatar
ORIGINAL: roundman
ORIGINAL: Dejavu
Thanks again guys
why would you want one set lower for burnout, and the other set higher for runnind down the track? always wondered that.....
bobby is offline
Old 03-08-2005, 10:35 PM
roundman
roundman's Avatar
it prevents the engine from running away from you while doing the burnout and doing engine damage from over-reving the engine. it's also easier to do this way as you can just floor the gas pedal for the burnout and the engine rpm will stay wherever the chip you choose tells it do without worrying about over-reving it.
some stick shift racers use a two step to have one limit for the starting line launch rpm and the other for the down track upper limit.
some racers use a 3rd step limiter which has a separate setting for the burnout, the starting line launch rpm, and the down track upper limiter.
by the way, if you run in the footbrake or no electronics classes in the brackets, most tracks don't allow the use of two steps unless you have a manual tranny.
roundman is offline
jwog666
12-27-2021 08:09 PM
baddog671
07-26-2016 01:20 PM
daltron
04-28-2016 08:10 PM
bradleyb
11-27-2015 07:50 PM
bradleyb
California Regional Chapter
10-01-2015 01:02 AM
Quick Reply: 6A ignition box
