SD to MAF
RE: SD to MAF
ok... 1st... yup the a9l works... 2nd, its not your ONLY option
if ur auto-any mass air ecu out of an auto car
if ur manual-any mass air ecu(auto or manual)
the only ones i remember off hand are a9l a9p c3w there are more though
and ofcourse i have to ask, why are you converting?
RE: SD to MAF
For the cam options.I picked up this cam and its been sitting in my closet for over a year now with some 1.6 rocker arms.And i was told i needed to convert over to Maf.
RE: SD to MAF
Comp Cam
Grind# XE264HR-14
Intake Exhaust
Valve adjustment .000 .000
Gross valve Lift .512.512
Duration @
.006 Tappet Lift 264 270
Valve Timing Open Closed
@ .006 INT: 22 BTDC 62 ABDC
EXH: 73BBDC17 ATDC
These Specs Are for Cam Installed
@ 110.0 Intake Center Line
Intake Exhaust
Duration @ .050 212 218
Lobe Lift .3210.3210
Lobe Seperation 114.0
These are the specs on the spec card for the cam .Any help would be muchly apperecated.If i dont have to switch that would be even better.
Grind# XE264HR-14
Intake Exhaust
Duration @
EXH: 73BBDC17 ATDC
Intake Exhaust
RE: SD to MAF
****... id run that SD... im getting ready(hopefully starting it up tonight) to run the xe270 which is i thing 1 step above what your talking about... i have my card right here, lol...
Intake Exhaust
Duration @
.006 Tappet Lift 270 276
@ .006 INT: 23 BTDC 66 ABDC
EXH:74BBDC21 ATDC
Intake Exhaust
Duration @ .050 218 224
so as you can see, both cams are similar, with mine being bigger...im gonna stay SD.. i dont see you having a problem doing so... from some of the numbers i see( i can explain if youd like) i think you will be fine... might take some tweaking to idle,but should be fine
now... some more questions, not related to the SD/MAF but related to the cam
what heads
what valve springs
what locks/retainers
what of that ^ do you already have, and what is it?
Intake Exhaust
Duration @
EXH:74BBDC21 ATDC
Intake Exhaust
what heads
what valve springs
RE: SD to MAF
tuning as far as what? as far as what you can tweek yourself?
timing
fuel pressure
tps(make sure its right anyway)
adj iac plate
and your going to have to **** w. the vac line from the mani to the map sensor... well dont have do, but might have to, depending on the cam... just to trick the map sensor into thinking theres either more vac, or to calm the pulses down...
timing
fuel pressure
adj iac plate
RE: SD to MAF
ORIGINAL: dimebag
Intake Exhaust
Duration @
EXH:74BBDC21 ATDC
Intake Exhaust
what heads
what valve springs
Intake Exhaust
Duration @
EXH:74BBDC21 ATDC
Intake Exhaust
what heads
what valve springs
jwog666
12-27-2021 08:09 PM
stangin1996gt
09-21-2015 11:01 AM
