reset base idle question
when i reset the idle and let it run for 2 min with the iac pluged in and then shut off for 2 min, after that do i drive it normal or drive the hell out of it then shut off for 2 min, ive heard 2 sides
RE: reset base idle question
what you should do is disconnect the battery for like 15 minutes and it will wipe out the stored memory in the computer for the idle. plug the battery back in and take it for a spin WOT a couple times and you should be good
mungodrums
Suspension
09-07-2015 07:22 PM
