Swaping Ingition Switch
Whats up guys, well my inginition switch (key on column) is getting pretty old and worn out. In fact it keeps wanting to shut off. I can feel the play in it, its just old and loose.....lol. Its like after I turn to start position and its running if you BEARLY touch it it shuts the car off. Frustrating to say the least. I've been reading a little about swapping them out, didn't know if any one had any tips or suggestions on doing this. Never done an ingition switch. Can I just pull the switch out of an old column with the key, or can I order a new one>?? Tips please, thanks guys!
Do I need to swap the whole column or can I just replace the switch.
RE: Swaping Ingition Switch
you can definately change just the switch, and as far as using one out of another car, unless you happen to have a parts car or access to one for free, a new one from Autozone or something isn't very expensive at all.
[align=left] [/align]
I can feel it. When I turn it to runit sags back, when I'm holding it in the run, I can hear the fuel pump turn on when I let go it shuts off. I gotta pull it off regaurdless, so I'll throw a meter on it adn make sure its getting power. Sound about right. Thanks for the info I didn't know local auto would have, you just saved me a hassle!
No, it doesn't sound right. The key switch is strickty mechanical, ONLY. It connects to a rod that travels down the column to the electrical part of the ignition switch mounted further down on the top of the column. It looks like this
[IMG]local://upfiles/29779/B3D805BE2CC34A3ABC8664B8F94B0CE5.gif[/IMG]
If you need to replace it
REMOVAL
[*]Disconnect battery ground cable.[*]Remove steering column trim shroud. For tilt column only, remove upper extension shroud.[*]Disconnect electrical connector from switch, Fig. 1.[*]Rotate ignition key to On (Run) position.[*]Drill out bolt heads securing switch to lock cylinder using a {1-8} inch twist drill. Remove bolts using an ``Easy Out' or equivalent.[*]Disengage switch from the actuator pin.[/ol]
INSTALLATION
[*]Adjust switch by sliding the carrier to the switch On (Run) position.[*]Check to ensure that the ignition key lock cylinder is in the On (Run) position by rotating the key lock cylinder approximately 90 degrees from the Lock position.[*]Install switch onto the actuator pin.[*]Secure the switch with new break-off head bolts. Tighten bolts until heads shear.[*]Connect electrical connector to switch.[*]Install steering column trim shroud. For tilt column only, install upper extension shroud.[*]Connect battery ground cable.[*]Check for proper operation.[/ol]
The lock cylinder part is a lil easier.
REMOVAL
INSTALLATION
I appreciate everyone looking out for my interest. I fixed it. Good call "PRO50SC" It was a loose connection harrness on the switch. Just wire tied around the column, a quick fix for now, she is solid and starts everytime. Once again I appreciate your efforts man! You Rock [sm=icon_rock.gif][sm=icon_rock.gif]
