Broken crank?
Broken crank?
I am looking at picking up an 87 GT that has a broken crank. He has a new crank for it just needs to be installed. How hard is this job and what is involved? He asking $1000 for the car and I might get it cheaper yet.
RE: Broken crank?
not always, sometimes the cranks do snap without damaging other things, but there is a good chance at a damaged main journal with means the block would need aline hone or may simply be toasted.
RE: Broken crank?
The body has some rust on the quarters around the wheel wells and under the rear glass. If there is that many potential complications then I am not going to bother. Thanks everyone. I was wanting to know if it was an easy fix or not.
RE: Broken crank?
ORIGINAL: Pearlkobra12
if the body is in good condition i'd prolly jump on it... but if it has a "broken crank" id imagine there is some other thing wrongs mechanically
RE: Broken crank?
In the original engine in my 91, the crank walked and snapped while the engine was at idle, and it cracked the number 1 and number 5 cylinders all the way up. Not saying that this is what always happens, but expect that if the crank broke at any RPM, there will probably be a bit of damage.
09-25-2015 06:58 PM
jessicarabbit
09-25-2015 12:41 PM
