winsdor heads
RE: winsdor heads
they will fit but dont waste your time- they arent any better than what you have. if you get 351W heads from 1969-1973 then they would be worth bolting on, or even some old 289 or 302 heads made in 1973 or earlier. All ford heads from 1974 and up suck ***, with the exception of gt40 heads and a few others.
RE: winsdor heads
Dan is right thay are *** . but if you do get a good 351W head ARP makes the bolts for the 351W head on the 302 . the 351 uses a bigger bolt . the ARP bolt is bigger on the top for the windsor head and smaller on the bottom for the 302 block
